Ansys Learning Forum › Forums › Discuss Simulation › Fluids › turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 640565 cells › Reply To: turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 640565 cells
October 16, 2024 at 8:57 am
You may need to check inlet boundary conditions. Do the number of cells hitting the limiter reduce with iterations?Â
