Ansys Learning Forum › Forums › Discuss Simulation › LS Dyna › Body hitting a net, SPH and Lagrangian approach › Reply To: Body hitting a net, SPH and Lagrangian approach
October 15, 2024 at 3:43 pm
Hi Otokemo,Â
Have you used any nodes_to_surface contact between SPH ( MAT_NULL+EOS)and Beams with adjusted penalty factors for contact to be detectable with a very fine particle count ( at least three or more particles covering the beam elements to get collisions) with this approach, you might get something like follows:
I do not suggest to use solid elements here to represent the fluid part, You can try with the solid net elements and see how it goes. Â
Cheers, RamÂ
