Ansys Learning Forum › Forums › Discuss Simulation › Electronics › Passive antenna noise floor › Reply To: Passive antenna noise floor
October 15, 2024 at 7:48 am
You can parametrize the ground surface in HFSS and run a parametric analysis there to see the impact of ground size on the results.
If you are using AEDT Circuit with the HFSS design embedded in it (co-simulation), you can define the ground parameters in HFSS as project variables and change them directly in Circuit
