Ansys Learning Forum Forums Discuss Simulation Fluids What is the difference between total heat transfer rate and total surface heat f Reply To: What is the difference between total heat transfer rate and total surface heat f
sjyang
Thank you for your reply. The inlet temperature is 700°C.
As I understand your reply, is it correct that the surface integral of the total surface heat flux is a function only available for walls, and should I use the total heat transfer rate in the flux report to know the heat flux at the inlet?
