Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › residual stress › Reply To: residual stress
October 14, 2024 at 11:52 am
Is your goal to combine the stress from the first analysis with the stress from a second analysis? If so, what you describe is not how you do that. Instead, you create a project with both analyses in it and use the Solution Combination feature to add the stresses together in a new result.
https://innovationspace.ansys.com/forum/ansys-bing-search/?q=solution%20combination
