Ansys Learning Forum Forums Discuss Simulation General Mechanical Can not build pressure vessel Reply To: Can not build pressure vessel
mohan.urs
Hey, If you are using student version. Try it in Spaceclaim rather than design modeler.
Check out this link which explains how to do that.
Drawing Pressure Vessel (ansys.com)
However if you want to use design modeler only, follow the same approach. It will work fine in DM too.
Let me know how it works out.
Thanks.
