Ansys Learning Forum Forums Installation and Licensing Ansys Free Student Software Error: An error occurred when post processor attempted to load a specific result Reply To: Error: An error occurred when post processor attempted to load a specific result
bram.dupre
Hi Reno,
I tried to access the documentation using the new link. However, I needed to log in using a customer number in as before:
I can’t enter a customer number as I don’t have one. I tried to retrieve one using the “Support: Retrieving Your Customer Number” page (https://www.ansys.com/support/retrieving-your-customer-number), but had this as output in the cmd, probably indicating no license/customer number has been set:
There is no other ansysli_util.exe present on my C-drive.
I was able to show different versions (defined in the XML) of LS-DYNA in Mechanical, but had errors while trying to solve (see screenshot in Ansys Mechanical in my previous post).
path of the “lsdyna_solvers.xml” folder:
C:\Users\\AppData\Roaming\Ansys\v242\ACTLSDYNA
Kind regards,
Bram
