Ansys Learning Forum Forums Installation and Licensing Ansys Free Student Software Error: An error occurred when post processor attempted to load a specific result Reply To: Error: An error occurred when post processor attempted to load a specific result
bram.dupre
I am using the student version of the software, as a university student (master) in industrial engineering.
I tried a simple compression of a cube. I still got the same errors. It is probably the installation, but I wonder if it might be a bug as I already tried this with version 2023 R2 and 2024 R2. I couldn’t test it on other PC’s yet. I found similar errors on other forums from previous versions claiming different things like the location of the project on the drive might be restricted by the administrator rights on Windows 11. I also found things related to the “\admodel_0.ad” file which should be “\admodel_0_0.adres” or so. I tried to solve the issue ith both methods without succes.
Could there be an error because I run this in Belgium? PC’s are set for decimal sign “,” instead of “.” in America etc. I found another article claiming a certain file path was using “;” instead of “.” which could be related to location defaults. I also tried to play with my PC’s settings, but had no succes so far.
Using LS-Dyna as a standalone simulation causes some new errors:
I found the issue also in “Error messages ‘The demanded solver was not found in the specified path’” on this forum, but no solution has been offered yet.
This looks like another file/path related error, there might be a link.
Kind regards,
Bram
