Ansys Learning Forum › Forums › Discuss Simulation › Photonics › Semiconductor FTO is not correctly configured.Please verify material properties. › Reply To: Semiconductor FTO is not correctly configured.Please verify material properties.
October 10, 2024 at 4:45 pm
The error message says material and configuration are incorrect. Since you checked that the data is correct, it might mean some parameters are missing, or improper. I would suggest you to compare the material data with another well known and similar material.
In addition, it seems your version is quite old. Please upgrade to the newest version.
