Ansys Learning Forum Forums Discuss Simulation Fluids Enable system coupling results option Reply To: Enable system coupling results option
taegoon
I'm really appreciate for your reply!
in system coupling gui, i entered DatamodelRoot().OutputControl.Results.Option='last step' and then click the Results in tree and set the last step or programme controled as follow. Then i selected the Type as Ensight gold as following your kind comment. However, the option is still off and SyC/Results folder was not generated.
But as you can see in the attached photo, i only specified the OutputControl in system coupling GUI!
do i need to set the option such as, participant and interface, to make it works?
if so can i get an examples or manual to set system coupling gui for the two way FSI by fluent and mechanical?
or is there any other way to solve it?
i sincerely need your help !
best regards,
