Ansys Learning Forum › Forums › Discuss Simulation › 3D Design › Surface Equation Generation not Showing Up in Ansys Discovery Script Editor › Reply To: Surface Equation Generation not Showing Up in Ansys Discovery Script Editor
October 9, 2024 at 1:25 pm
Have you treid after removing the ClearAll() command? Do you surface created in Model Tree?
Refer to my first image where you can see Radial Wave surface in the model tree.
Please check the above images. First create a surface, you should see surface created in Model Tree.Â
Then run the scriipt as shown in the editor.
Regards
Atharv
