Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Surface export from Fluent to any CAD format › Reply To: Surface export from Fluent to any CAD format
October 7, 2024 at 10:50 am
The simple approach is to export a VRML via post processing. Otherwise, if you read the boundary mesh into Fluent Meshing you should be able to strip everything you don't want to take the eroded surface mesh into CAD.Â
