Ansys Learning Forum Forums Discuss Simulation Fluids Simulating solar collector Reply To: Simulating solar collector
Bumping threads after about 14 hours is unnecessary - staff work office hours based on location, so response times will vary.
If you've not plotted the flux & monitor data you may want to investigate that. That may require you to run the model on.
The hot streaks in the second plot don't make much sense, hence comments regarding the convergence.Â
