Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Issue when recreating tensile test with ansys workbench › Reply To: Issue when recreating tensile test with ansys workbench
October 2, 2024 at 2:54 pm
Hi Sebastian,
Could you describe how you defined the hardening curve (stress versus plastic strain) in the Engineering Data? If you don't expect reverse loading to activate kinematic hardening effects, I would suggest that you employ "Multilinear Isotropic Hardening" instead.Â
