Ansys Learning Forum Forums Discuss Simulation Electronics Inconsistent results between Terminal Wave Port and Terminal Lumped Port… Reply To: Inconsistent results between Terminal Wave Port and Terminal Lumped Port…
Aymen Mzoughi
You can tighten the maximum delta z0 in the solution setup if more accuracy is needed:
