Ansys Learning Forum › Forums › Discuss Simulation › Preprocessing › Load Key value for SFE command › Reply To: Load Key value for SFE command
September 27, 2024 at 8:02 am
Thank you for the response.
Right now I'm using Hex20 thermal solid element.
When I select the component "a1" using CMSEL / CM command, and use this component name for SF command syntax, it shows error saying that SF can be used with "blank, all or P (picked nodes)", the nodes dont get looped in the DO loop and hence component name cannot be used.
Does SF command work with surf15x elemets only?
