Ansys Learning Forum › Forums › Installation and Licensing › Ansys Products › Moving Heat Source \ Doughnut beam shape › Reply To: Moving Heat Source \ Doughnut beam shape
September 26, 2024 at 2:45 pm
dlooman
There's probably no resources or video on that, but if you create radiation between two objects you can move the source object with displacements and request the view factors be updated during the solution with the APDL VFUP command (VFUP,,ON).
