Ansys Learning Forum Forums Discuss Simulation Preprocessing Shell Mesh Joint with Bolt Pretension: Contact between the beam & hole Reply To: Shell Mesh Joint with Bolt Pretension: Contact between the beam & hole
mohan.urs
Hey,
This post seems relevent to contact between beam and hole. Do check it out once.
Contact formulation for beam with bolted joints, using shell elements (ansys.com)
Thanks
