Ansys Learning Forum Forums Discuss Simulation General Mechanical How to fix “internal solution magnitude limit was exceeded” error Reply To: How to fix “internal solution magnitude limit was exceeded” error
Erik Kostson
Hi
Common issue when using beams or multiple parts. At the moment the beams/members are not connected to each other at common vertex.
USe shared topology in spaceclaim to connect all the beam nodes shared by the members (now they are not connected as we said).
The below video at a time ~ 3 minutes and 40 sec. into the videoclip shows how to share topology and connect them at common vertices.
https://www.youtube.com/watch?v=hb7BUcug8wY&t=435s
All the best
Erik
