Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Coordinate System Aligned to Nodes › Reply To: Coordinate System Aligned to Nodes
September 20, 2024 at 2:05 pm
Hi
There is no automatic way to do what you want, but you can cacluate the direction vector between the nodes and add that to a user defined coordinate system (say being the PrimaryAxisDirection of the coordinate system) in Mechanical.Â
Another way could be to use dierectly in the construction path (Two Points option), to scope Point one (start) to first node and the second end Point of path to the other node.
These are some ideas.
Perhaps forum members have some more ideas.
All the best
Erik
