Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Convergence issue in hydrogen-powered gas turbine combustion chamber › Reply To: Convergence issue in hydrogen-powered gas turbine combustion chamber
September 20, 2024 at 9:00 am
I would suggest you to first use EDM with RTE and converge it. Then move on to EDC since it is a bit heavy model. Select High Order Relaxation term and select Warped Face correction. Also please use psuedo time step. Lastly, please do not judge the convergence solely based on the scaled residuals. Check the net mass and heat flow rate. Also check for the report definitions.
