Ansys Learning Forum › Forums › Discuss Simulation › Photonics › far field projection of gaussian beam › Reply To: far field projection of gaussian beam
September 19, 2024 at 11:28 pm
The source beam profile is correct. The monitor data is after some propagation. It is hard to say what causes this shallow center. You can place a xz plane monitor and check the field profile. You may also check Born&Wolf's book for fields near focus plane. It is not a solid cone as expected intuitively.
