Ansys Learning Forum Forums Discuss Simulation Photonics A question about laser modulation bandwidth simulation Reply To: A question about laser modulation bandwidth simulation
Guilin Sun
The default value might be commonly used for a material, or it can be arbitrary.  As your previous post answered, if you know the material and doping properties you can calculate tehm. From my knowledge many of the semiconductor material properties are empirical, unlike many other physical properties that can be easily measured. Ideally you should calculate your own data if possible. You may need to consult some references for more details. The software just needs those parameters. One thing you can keep in mind: your simulation result can only be as good as your model, including the material/doping properties. They depend on your input. The software does not guarantee the correctness of the material data as it is only for your convenience. Please check and confirm if you can.
