Ansys Learning Forum Forums Discuss Simulation General Mechanical Inverse reserve factor contours on solid composite model does not show up? Reply To: Inverse reserve factor contours on solid composite model does not show up?
Deepak
I tried the 2024R2 Version, and it was working fine. Can you please tell me on which version it’s not showing?
Please try inserting the Inverse Reserve Factor (IRF) manually under Composite Failure Tool.
Thanks,
Deepak
