Ansys Learning Forum Forums Discuss Simulation LS Dyna LS Dyna CESE solver Reply To: LS Dyna CESE solver
Atish Gawale
1) If you have defined composition of fluid using *CHEMISTRY keywords, then you need to use CESE_INITIAL_CHEMISTRY otherwise use CESE_INITIAL. Then you must also specify the CESE_MAT_GAS and CESE_EOS.
2) Yes, you need to create the SET_SOLID for each composition and they should not overlap.
3) Grid size should be very small. Min size can be less than 1cm in the combustion domain. I will recommend structured hex mesh.
4) Error is typical with CESE solver. If solver finds anything non-physical then it gives only one typical error for any problem. Be is related to mesh size, time step size, non-physical pressure, temperatures, boundary conditions or any other problems.
Atish
