Ansys Learning Forum Forums Discuss Simulation Preprocessing Load Key value for SFE command Reply To: Load Key value for SFE command
danielshaw
You can use the SF command or define surface effect elements (SURF15x) and use them to apply the HFLUX.  Why can’t you select nodes for use with the SF command?
