Ansys Learning Forum Forums Discuss Simulation 3D Design My question is as follows Reply To: My question is as follows
liu377997
Hello, I would like to ask how the connection between the "Solution" in the Transient Structural module and the "Results" in Fluid Flow (Fluent) is achieved in your video. I followed the same setup in Ansys Workbench, but I am unable to establish this connection at this step. I'm unsure if it is a software issue or something else. I would appreciate your guidance. Thank you, my friend.However, after failing to create the connection between the 'Solution' in the Transient Structural module and the 'Results' in Fluid Flow (Fluent), ANSYS Workbench prompts the message: 'Unable to load ACT extension. If continuation involves self-interaction, you might encounter restrictive behavior.'
