Ansys Learning Forum › Forums › Discuss Simulation › 3D Design › Lower the minimum length than 50nm › Reply To: Lower the minimum length than 50nm
September 17, 2024 at 5:44 pm
Check this help page: Model Size Box (ansys.com)
Make sure you set the units to Microns, then import the geometry. Then apply shared topology
Set the units to Micron and start a new session. You should see that DM opens with micrometer units
