Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Node 999999 Fatal signal raised sig = Segmentation fault › Reply To: Node 999999 Fatal signal raised sig = Segmentation fault
September 16, 2024 at 1:27 pm
Work on the local drive and by all means then back up with OneDrive. We use this configuration at work. Note, with Windows it's sometimes necessary to unload a UDF to then compile again as Windows won't let you modify an open folder: LINUX doesn't suffer from this.Â
