Ansys Learning Forum Forums Discuss Simulation Fluids Rotating and mass flow inlet Reply To: Rotating and mass flow inlet
warhammer975
Thank you very much, this helped me move forward in solving the problem. Can you help me with another question? How can I create a ring region of cells (with certain inner and outer radii) in the same way? I chose the "cylinder" shape in Adapt - Region, which should correspond to a ring for a two-dimensional problem, but I only get a rectangular region of cells
