Ansys Learning Forum Forums Discuss Simulation Fluids Node 999999 Fatal signal raised sig = Segmentation fault Reply To: Node 999999 Fatal signal raised sig = Segmentation fault
Turn off the expression & input UDF. What happens? If it works, turn on the expression based motion. What happens?Â
