Ansys Learning Forum › Forums › Discuss Simulation › Photonics › Calculating heat generation profile in FDTD using narrow band CW sources › Reply To: Calculating heat generation profile in FDTD using narrow band CW sources
September 10, 2024 at 4:21 pm
The analysis group can be used when the wavelength recorded by the monitor is laser, single wavelength. You can use the Advanced analysis group:
to get the absorbed power, and convert to the actual laser power in thermal simulation.
https://optics.ansys.com/hc/en-us/articles/360034915693-Calculating-absorbed-optical-power-Higher-accuracy
