Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Rotating and mass flow inlet › Reply To: Rotating and mass flow inlet
September 9, 2024 at 1:47 pm
Hello!
Yes, I want the mass flow to be evenly distributed across the entire surface of the inner cylinder (this cylinder must rotate at a given speed) into the gap between the cylinders.
There was an idea to pump this mass flow into the first wall cells near the inner cylinder using UDF, but so far I have not been able to do this, I need more experience in this matter.
