Ansys Learning Forum Forums Discuss Simulation Fluids The difference in velocity vector and contour Reply To: The difference in velocity vector and contour
Federico
If you have a non-slip boundary condition on the walls, your velocity will be zero on those faces. As you mention, creating different surfaces away from the walls, you should be able to see the velocity > 0m/s
