Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Unexpected result in tensile test: Bending effect due to Tensile load › Reply To: Unexpected result in tensile test: Bending effect due to Tensile load
September 8, 2024 at 5:22 pm
peteroznewman
In SpaceClaim, create an XZ plane at the center of the width of the solid. Use Split Body to slice the solid into two pieces. Delete one half. Select the XZ plane, click the Mirror button then click the half solid. You will now have a perfectly symmetrical body.
