Ansys Learning Forum › Forums › Discuss Simulation › Preprocessing › Meshing problem with die-extrudate interface › Reply To: Meshing problem with die-extrudate interface
First use Right Click on Mesh and use Show → Sweepable bodies. It should show cylindrical die as sweepable body. If not then there may be sliver face somewhere.Â
With Sweep method, you will need to define inflation on face. Here you will need to define it on Outler. So you need to select that face and edge while defining inflation on that face. Then you will need to use outlet as source face in sweep. This should give you sweep mesh in cylindrical die.Â
For conical die, it is not clear from image if it is sweepable or not. You may want to split it at different locations to make it sweep.Â
PLEASE CHECK FOLLOWING VIDEOS
ANSYS MESHING SIZING:
HTTPS://WWW.YOUTUBE.COM/WATCH?V=W4Q6Q8NKF3U
ANSYS MESHING: DECOMPOSITION FOR HEX MESHING:
HTTPS://WWW.YOUTUBE.COM/WATCH?V=P19GOTQWMC0
ANSYS MESHING: MESHING METHODS:
HTTPS://WWW.YOUTUBE.COM/WATCH?V=NEOC8RDNNRO
ANSYS MESHING: INFLATION:
HTTPS://WWW.YOUTUBE.COM/WATCH?V=LREHXIZRHC0
REGARDS,
KEYUR
HOW TO ACCESS ANSYS ONLINE HELP DOCUMENT
GUIDELINES ON THE STUDENT COMMUNITY
FLUIDS ENGINEERING COURSES | ANSYS INNOVATION COURSES
