Ansys Learning Forum › Forums › Discuss Simulation › Fluids › mixing of gases, no combustion › Reply To: mixing of gases, no combustion
August 28, 2024 at 8:57 am
Check the pressure field after the initialisation process. Also, what stops the mixing region dropping to 100,000 Pa very quickly once it's running? The pressure based coupled solver is good to about 3M so you may not need the Density based solver.Â
