Ansys Learning Forum Forums Discuss Simulation Fluids TUI command regarding saving fluent data on HPC Reply To: TUI command regarding saving fluent data on HPC
It's visible here
The menus can change slightly as options are turned on/off or files are loaded. There are also a few legacy commands where a menu structure has been updated but an older form of a TUI command is still available to avoid problems with journals.Â
