Ansys Learning Forum › Forums › Discuss Simulation › Electronics › How to calculate capacitance using Fields Calculator in HFSS? › Reply To: How to calculate capacitance using Fields Calculator in HFSS?
August 27, 2024 at 8:15 pm
I found some Capacitance values for this structure using Q3D but HFSS is giving completely different results, so I want to find the capacitance from the HFSS fields. I can do C = Q/V with V= Line integral of the Electric field and Q as the Abs_Q value in the fields calculator. But I am unsure if this is the correct approach.
