Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Temperature-dependent friction on a brake disk › Reply To: Temperature-dependent friction on a brake disk
Hi you can add it (APDL command snippet) under the contact (as done here - https://innovationspace.ansys.com/forum/forums/topic/contact-pair-command-object/) –
below is an example based on your question - change friction values and temps, as needed.
TB,FRIC,cid,2,,ISO Â Â ! Activate isotropic friction model
TBTEMP,0.0 Â Â Â Â ! Define first temperature
TBDATA,1,0.0 Â Â Â Â Â ! Define coefficient of friction at temp 0
TBTEMP,100.0 Â Â Â Â ! Define second temperature
TBDATA,1,0.2 Â Â Â Â Â ! Define coefficient of friction at temp 100
TB,FRIC,tid,2,,ISO Â Â ! Activate isotropic friction model
TBDATA,1,0.2 Â Â Â Â Â ! Define coefficient of friction at temp 100.0
