Ansys Learning Forum Forums Discuss Simulation Electronics How to calculate eddy and hysteresis losses of the core? Reply To: How to calculate eddy and hysteresis losses of the core?
HDLI
Hello Sai,
      It seems that the resistivity is extramely high and can be ignored, so we do not need consider skin effect in the core. However, you may need to consider skin depth in wires if the wire size is not small enough, to get correct copper loss.
      For the core loss, please just integrate EM losses over the volume in the original result. If it is not density, does the result make sense? Thanks.
HDLI
