Mayur.Lokhande
Bbp_participant
The eliptical component is not having any effect of temperature though it is close to rectangle component which is at 100degree C. In actual due to 100degree temp. of rectangle component surrounding air should be heated up and the eliptical component should show temp higher than ambiet..right
