Timos
Hello, to create a cross-section of a 3D object in ANSYS, you should use the Modeler > Surface > Section command. This command allows you to create cross sections of 3D objects on the XY, YZ, or XZ plane, resulting in 2D closed polyline objects. Here are the steps you should follow:
1. Set the working coordinate system you want to use for the cross-section plane.
2. Select the object from which you want to create a cross section.
3. From the menu bar, click Modeler > Surface > Section.
Make sure that the object you are trying to create a cross-section from is a 3D object, as the command is intended for this purpose. If you continue to experience issues, it may be beneficial to consult the ANSYS documentation or support for further assistance with the specific error message you are encountering.
