Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Fluent expression syntax error › Reply To: Fluent expression syntax error
August 19, 2024 at 12:07 pm
Not sure what you mean by that.
The expression you shared works as intended. Like I said, StrainRate does not have a single value, so the message you see is to be expected on the expression definition page.
