Ansys Learning Forum Forums Discuss Simulation 3D Design High temperature in the CFD results Reply To: High temperature in the CFD results
NickFL
Are there large areas that are showing these extreme temperatures (there is also -181°C region)? Or is it simply a couple of cells? What is the mesh quality in these regions?
I am not exactly sure what your problem is, can you simulate it as isothermal? And then turn on the energy equation after the solution is mostly converged.Â
