Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Setting Up MRF Case › Reply To: Setting Up MRF Case
August 15, 2024 at 9:19 am
Correct. What is wall-int ? The mrf should be an interior.Â
As it's an unbaffled tank you could set a single fluid zone with moving walls on the mixer (as you have) and the tank walls as either stationary or moving at absolute rpm of zero.Â
