K Kramer
Bbp_participant
 -> "You should be able to orient your bearing load using the define by - vector"
Yes, but as I said this will just cause the load to act on the opposing side of the surface, while it is still compressive. It would be good to include an option to change the load direction from compressive to tensile, which is currently not possible.
