Ansys Learning Forum › Forums › Discuss Simulation › Electronics › Mesh size restrictions Ansys Electronics Student version › Reply To: Mesh size restrictions Ansys Electronics Student version
August 14, 2024 at 1:05 am
Hi Chinmay,
I followed your suggestion and navigated to the analysis solution setup.
I found the default value for 'Maximum number of passess' to be 15 which when analysed resulted in a mesh size of 91950 volume elements. I adjusted the value of 15 down to 5 and reanalysed, the volume elements did not lower. I further reduce the number of passes down to 1 and the value did not lower. In the below screen shot are the error messages for each analysis attempt with a reduce value for number of passes. Â
Do you have any other suggestions?
Thank you
