Ansys Learning Forum Forums Discuss Simulation Fluids How to determine average residence time of fluid Reply To: How to determine average residence time of fluid
If you save case & data then switch to steady that opens up the pathlines option with no extra calculation. If you also freeze the flow (look in the Equations in Solver section) you just need to run the scalar calc, that ought to converge in a few hundred iterations and it's only a single equation to solve.Â
