Ansys Learning Forum Forums Discuss Simulation General Mechanical About mesh convergence error due to negative jacobian Reply To: About mesh convergence error due to negative jacobian
Ashish Khemka
Can you try remeshing the model with tetrahedral mesh? Are you applying a hex dominant meshing method? Can you change the unit system to small units?
Ashish Khemka
